2700-2800rpm at 70mph in 6th is right.
Little disappointed in this. I was expecting it to have 5 gears fairly close together and then an economy gear. Is the engine not quite loud?
Good job!
How thick is the metal? Heard a lot of people says 'screws', can't it be done with nuts and bolts and washers?
Forgot to add it has had 4 brand new Pirelli P Zero Rosso's fitted to
Anyone know anything about these? They good?
Yeah they do lose brightness over time. The new bulbs I put in were noticeably brighter than the ones they replaced but they are likely a better performing bulb from stock anyway.Oh I didn't realise you upgraded.
I already have xenon headlights on mine.
Not sure how the bulbs fair over time, wether they lose brightness or whatever. :S
