Could be to do with Google Now?
It's a sad day today. Last week I put my phone in the washing machine stupidly. After 5 days in rice, it kind of worked (powered on) but it fails to determine what the battery life is (so it jumps between 100%, 0%, 50%, 72%, etc). I sent it to samsung but they said the cost of repair is larger than the handset itself.
Guess I need to search for a new phone now. At least I'm on Giffgaff. What's the cheapest phone I can get which has tethering?
Ok guys, since the time change last night, my phone obviously auto updated to the correct time, but my accu weather widget still shows the time one hour behind.
The refresh button doest sort the problem and I've looked in the widgets settings options, any idea how I get it to display 6:32pm rather than 5:32pm?
Reboot the phone for all widget problems for anyone who still has this issue.
Still no JB update on kies for my unlocked S2 from CPW..
Anyone had their USB port messing about with the charging and battery blinking? Luckily it was an easy fix by using a toothbrush and some air can dusting had to open the whole back case though to check it out. Is this a common problem?
replaced both of them, you got off lightly tbh!
its good that they 7quid each.. afaik the ones in s3 are connected to main board so it would cost a load more.Shambolic isn't it?
Most likely this.
I usually get 2 days out of my S2 with a 4.2.2 ROM, very little use. I turn on Google now, same low usage and I'll get 1 day.
