1708797 - Heated
1708796 - Non-Heated
Thanks, whats the benefit of having the heated versions ?
I drove one of these Monday, what sort of boost do they make standard?
Was a 57 plate.
You can sit on them when its cold and it stops you getting a cold bum![]()
Que?
Golf GTI.
My local Ford dealer is getting a ST-3 in for me to look at. It's a 2010 model that's done 16,000 miles.
Assuming it's immaculate does £13,000 sound reasonable from a main dealer?
It's just what I want (Blue, 3 Door) the only thing putting me off is that I would prefer the 2010.25 ST-3 spec that had climate control, key less entry, auto mirrors, wipers, lights, etc as standard.
As i'm going to spend top money, that's the only doubt I have.
Wtf. Was you doing 10mph in 6th gear?!
To be fair I can get mid 30s on the motorway, driving normally.
