Drive re-gripped......
WHAT
A
DIFFERENCE
I do not know why I waited so long, was very difficult to hold/grip now it is effortless. really niceMay get the rest done over a few months, cant really take the hit for £90 on grips that I dont really need.
well........?
Keep an eye on the American Golf website, I picked up 12 Golf Pride VDR grips for £1 each a couple of weeks ago.
Also you chaps should do your own regripping , very easy to do.
Can anyone recommend a driver for a relative newbie?
Got some vouchers from work to use with American Golf, can probably go to about £80. Maybe more if there's a good deal on.
Cheaper end of the scale but do still get the occasional nod of approval from the mags. Similar sort of standing to MD though MD make fantastic wedges.Thanks for the suggestions. I'm not sure on the adjustable head thingybob, I'd end up with it set badly
Never heard of Benross. They any good?
I've got another voucher for a couple of lessons but I wanted to take a driver with me so I could be sure on technique.
I was offered a Ping G15 for £60 before I knew what was what and because I'd seen the price of clubs at Sports Direct I thought that was a lot.
Seems I was mistaken!
Will call into AG and see if they have anything second hand. I'm sure they'd take vouchers for them.
