Y'know what? Moments like those are rare.
I regret nothing![]()
True, and of false alarms it was a beauty.
It was actually Techreport who first noted it i believe.
So that's why Titan is worth so much![]()
Trust me those blue spikes will be very noticeable when you're playing and pcper say as much. The 4gb 680 has no spikes at all.
That's a lot of spixels and its only bf3 that the 2gb suffers any performance loss on. It still does better than the 7970 crossfire disaster and many people said they never noticed any problems.But..but... its 3840x2160 on ultra settingsThat's a lot of spixels and its only bf3 that the 2gb suffers any performance loss on. It still does better than the 7970 crossfire disaster any many people said they never noticed any problems.
Those spikes will almost certainly be because of VRAM. If there isn't enough video memory to cache all the data needed, the game will run - but now and then it will have to go to system RAM (or at worst, disk) to fetch data, causing this kind of blip.
It's also worth noting, you need 2 Titans worth of power to provide even somewhat playable gameplay what roughly translates into 3 680s lol.
So yeah, not really an issue, unless like we've said...you're planning on going Tri-SLI and multi monitor.
Indeed. It seems fairly obvious to me that to run Ultra with X4AA at 1440/1600p you're going to need a 3gb card. Why else would 3gb be in the recommended requirements? Last year it was 2gb recommended requirements and generally that limit is not exceeded on single screen in Battlefield 3.
The limits have not been increased for no reason. Dice would not do that if there is no chance of more than 2gb being used.
Recommended graphics card: 7870/660
Recommended graphics memory: 3GB
Eh?
This is the point though that many people dont seem to be getting, At those resolutions you wont get above 60fps with ANY single gpu card at max settings, so whats the point in using max settings on a 2gb or 3gb or even a 6gb card?
I've even bet Matt a free copy of the game if i'm wrong. (single card gives playable framerate but exceeds VRAM limit)
Probably need something like 3, 2GB cards to actually provide enough grunt to push the settings required to push over the VRAM wall whilst still maintaining playable FPS.
I'll buy you BF4 if that's not the case.
This is what you said.
As i said earlier i reckon two cards will be able to provide playable fps and exceed the 2gb limit.
Get ready to buy me a copy of Battlefield 4 Tone.![]()
Battlefield 3's recommended specs were only 1gb though and usage definitely went way over that. So does that mean the same will happen with Bf4? One would think so.![]()
One things for sure a vram requirement of 3gb would not be there if its not needed, depending on settings and resolution used.
^ This basically.
Been pointed out hundreds of times.
So what you're saying is DICE got the recommended VRAM wrong for BF3 but if they say 3GB for BF4 then this must be right?
Maybe they realised they got it too low last time so are playing it safe and overestimating this time?
I seem to recall a similar argument around BF3 time saying any card with less VRAM than AMDs current card (2GB 6970) wouldn't be able to max it out. I wonder if any 580 owners managed it then? I seem to recall my 570 SLI doing OK.
That would be a safe bet to me
I bet you and Matt, that if both of us are wrong, I will buy a 9xxx or a 780 for myself![]()
