Cool.
I would be mindful of using belts unless you really know what you're doing, and that you don't grow to rely on it. You'll notice a lot of the bigger lifters on here ditching the belts on the odd occasion to work on their 'raw' lifting and make sure their underpinning technique is good.
Notedthanks for the advice
Never used one myself and when I did try I didn't know how to brace my core properly anyway! Not had the desire/need to try since.
No problem using one provided it's not just an accessory and is only used when required.
