Caporegime
- 18 Sep 2009
- Dormanstown.
Which would point to it being vram related imo as you're using more at a higher resolution.
@Sh0ckdoctrine
I have seen my 290x drop to about 45fps on the same map but i noticed this when the card was throttling. So i raised the fan speed to about 45ish constaint to keep it sweet and the power target to + 50% and now on the same map i dont have a problem.
Seems like my card is power crazy/ hungry and needs a bit more fan and power target at stock to ensure it does not throttleThis is on the beta 9.2 drivers i did not get it on the older ones going to roll back the driver and see if it changes i am sure the 9.2 ones were meant to change the way the fan speed was calculated and make it work a little harder/smarter but i think its a little worse on my card now.
hope that helps a little.
My replacement Sapphire turned up today. Elpida memory.
Benched for 4 hours this evening and could *not* replicate the issue.
Go figure.
(No haribo in RMA replacements, taking the ****. Going to shop elsewhere now.)
Go figure.
Kudos to OC for the quick replacement. So new one works fine with no other changes, the old one must have had something wrong with it.
I still dont see what the updated driver fix is going to do for others other than mask the problem somehow.
Ok so I have done some testing on my card.
I have an Asus 290x on Beta 9.2 on win 8.1.
Stock volts, 50+ power limit, running 1160/1500. 4 hours of BF4 and benching, no artifacts or no black screens.
I will test games in higher volts. I can push 1270/1600 with 1.3v on stock bios.
Edit: I also have Elpida memory
Thats a nice overclock 1270/1600 @ 1.3v thats great are you under water ?
On the stock cooler @1.3v with my asus bios flashed sapphire on the stock cooler with fan @ 100% i can only get to 1170/1600 without any artifacts i am wondering if i dont have a good clocker my asic is 71.9% so just looking for some info and trying to work out if i go water will i be able to push it any more ?
any ideas whould be great cheers dudes.
hard to say, I tried cool it with outside air my 290 would still artefact at to much mhz. It might help a bit with watercooling though but I dont expect things to take off much, the card can do more but cant say I am dissapointed with 200mhz+ oc.
