- 16 Oct 2012
Some of these builds look amazing. I for one will be picking up this case next week. Really looking forward to it!
will 360mm rad 60mm thick fit in the top of this case in push/pull configuration(50mm)
how big is the clearance in the top?
ta
Just picked up a 750D myself, had a quick look inside and noticed raised motherboard mounts where the standoffs normally go, do you still have to insert standoffs or do you just screw the mobo straight on top of the fitted raised mounts?
Got a H100i too, are you guys exhausting or intake with this cooler?
I'll put up some picks when I have built it. Lovely case. @ Too Tall, loved the way you overlaid those home made stickers on your PSU and SSD, made all the difference![]()
No need for motherboard stand offs the one in the middle of the case holds it in place and the other raised ones are there to be screwed directly in to.
If you have ample air coming in from the front/bottom of the case I would have the H100i in exhaust mode.
Thanks, that's cleared that up, lovely touch by corsair, exhaust mode it will be then, always had my antec kuhler in exhaust. Just one other thing, so I don't have to remove the pin thing in the middle and put a screw in?
No you leave that one in, it lines your board up.
I'm building in a 750D just now, but my current board is Micro ATX so I need to use some stand-offs for a couple of the motherboard holes, but only one stand-off was supplied in the screw kit even though the manual said there should be 4.
Anyone else had this issue? I tried to borrow a stand-off from my previous case but the thread is not wide enough.
Yeah, did leave it in, great idea that, it made installation even easier. Thanks.
