*** Official AMD 7990 Owners Thread ***
^^ Thank gosh for that.
Next step is biosing and overclocking both GPU and CPU. Cheers for all the resources and help it is much appreciated.
Guys i pretty much solved my coil whine by using two different pci-e cables plugged into the card rather than one cable with two 4pins on it.
Just installed my new modular and will see if the not very common coil whine is still present as I done this just now.
Hi guys,
Has anyone tried mining litecoins with a gigabyte 7990? I bought 10 of them and they seem to just instantly crash, yet run furmark etc fine...
PSU is Corsair RM1000 so I think they should work.....
Cheers,
Not disabled ULPS but have flashed it and was getting around 80FPS in BF4 on ultra
Disable ULPS (via afterburner) then compare it to your 690. If you run at stock you can probably under volt it to 1.100v-1.175v, keep temps down and keep auto fan nice and low.
Oh where do I disable it ? Ps Thanks for the bios - Its very good - Looks like Im keeping my 7990 ! Good thing I completed AC4 on the 690 though.
