^^ Thank gosh for that.
Next step is biosing and overclocking both GPU and CPU. Cheers for all the resources and help it is much appreciated.
Just installed it and flashed it![]()
Guys i pretty much solved my coil whine by using two different pci-e cables plugged into the card rather than one cable with two 4pins on it.
Hi guys,
Has anyone tried mining litecoins with a gigabyte 7990? I bought 10 of them and they seem to just instantly crash, yet run furmark etc fine...
PSU is Corsair RM1000 so I think they should work.....
Cheers,
Yes ten.
wow,you might not have enough juice mate
Ok, so far - No coil whine I can hear - just played 1 hr of Bf4 And its nice.
Not disabled ULPS but have flashed it and was getting around 80FPS in BF4 on ultra
