actually ive unlocked mine and still cant move the slider....wtf ?
Are you using AB Beta 17? This one unlocks +100mv voltage on 290 cards.
Initially i thought the Sapphire was better but actually the MSI might be the better overall option.
Purely because of the longer warranty? Because at first glance the cooling system seems slightly less efficient - and I would imagine, ever so slightly louder.
Won't the latest beta not do?
It's also a lot shorter than the Sapphire.
Those of you with the 290, what idle temps are you getting and what fan speed are you using?
Thanks
upcoming Lightning (but that one is end of Feb/March timeframe).
Feb/March - according to Mark from MSI
idle temps like 32c
fan speed 42%
rpm around 1816
Feb/March - according to Mark from MSI![]()
The guy on the right looks like a b grade dutch porn star. The sort that would come to fix your fridge and end up servicing your mrs at the same time.
Nothing so custom about MSI Gaming Edition (obviously excluding HSF) - carbon copy pcb layout, same pwm controller, same 5+1+1 phase design. The only proper custom design so far is Asus DCU2 and upcoming Lightning (but that one is end of Feb/March timeframe).
Is it normal for the clocks to fluctuate during gaming from about 850mhz to 1000mhz? Temps never go above 78c.
Are you using the 13.30 beta drivers? If so use the 13.12 WHQL drivers. 13.30 are Kaveri drivers not for discrete gpu's.
Yes mate using the 13.12 from AMD website. I was expecting temps like this because my case is rubbish (enermax ostrog) was just wondering if adding another side fan to extract air would help. My previous 7950 Twin Frozr had the same problem, dumping a lot of hot air into the case. Was thinking of buying a Corsair 540..
