Just a hunch. i will ask Sam in TeamSpeak next time i play BF4 with him![]()
Did you get that Matt? or maybe i should talk to Roy?
Did you get that Matt? or maybe i should talk to Roy?![]()
Did you not see the screenshots scotty posted with a stock water cooled titan? They were right around the fps of that bench. The results look correct to me.
I'm jelly.
I'd invite Sam to our team speak but our lot can get a bit rowdy and are not very pc. Pretty sure any sane person would run a mile after 5 minutes on TS with the degenerates of 247.
In other news though got a follow from Roy today on twitter. You know you've made it when that happens.![]()
Where?
My mistake they were 1440P upon checking.
Until we know how they benched though, its a pointless debate.
Really, i got that follow Months ago, had a brief Email chat with David Baumann a few weeks ago to.![]()
@Matt
Crossfire with Mantle Borderless mode
I wonder if im getting a pci-e 2.0 x8 x8 bottleneck.
Now you're just showing off.
It has become completely meaningless.
Probably will make a small difference I would think.
That's the only thing I can think off. Before when we was both getting same results I was also running 8x - 8x PCI 2.0
I now running 16x - 8x PCI 2.0
Got a link to the article?
God dammit, another upgrade required. Will have to look into getting a new board. Is it possible to get a pci-e 2.0 x16 x16 board or is x16 x8 my only option? I don't want to change cpu as my i7 is good.
While there is something to that in general with benchmarking as I said you can use the settings they are using and hunt out the very worst possible situation to benchmark in (so within reason it doesn't really matter how they benchmarked) and still see numbers comfortably above what they have recorded which is why it raises my eyebrows so to speak. As I said I have to run around the map hunting out the worst possible scenarios while compounding that with video capturing to get close to as low as they have and thats with a 780 not 780ti so for me it looks very odd.
My MB does 16x - 16x Asus p8z77 ws using i7 2600k
But because I wanted the cards so far away one is in the 16x and the other is in 8x
But is this worth it to you just to record Mantle in borderless mode? why not wait for the SDK and other programs to work with it.
My change was needed to help with Crossfire temps.
what article?
The one with that slide? its around here somehere. i will try to dig it up, might not be until after TopGear.
Bah.....^^^
Google rules. and so do i.
http://www.pcgameshardware.de/Battl...tlefield-4-Second-Assault-Benchmarks-1109970/
He's speaking about himself. Lt always lowers the tone.![]()
