Close enough?![]()
Ediot: FML wrong set of trees!!!!!
I was looking at the other screens on my phone and thought "yeah that looks about right"
Then put them window by window on my PC and realised I'd derped.
this one?
 spot on thanks.a nudge above my retail stock clocks at 1150/6800 (from 1110/6200) due to a custom bios.
That is quite interesting, your DirectX results smash mine. How much a Difference you think 977/1250 vs 1150/6800 would make.
Then my Mantle on stock is a good bit ahead.
Why the hell are you only running your cards at 977mhz shanks? Even i run my reffy blowers undervolted -0.037v at 1000 core.
I have no need to run anymore tbh lol Dont Bench and these smash everything I give them. I also running -0.031v
Furry muff, but you're also at 1080P. Now it makes sense. Jokes aside i don't suppose my 23mhz increase makes much difference.![]()
It shouldn't make that much difference, iirc the vast majority of 780 oc editions boost to 1000+MHz out of the box which by contrast can also make it difficult to compare with other cards. 1100+MHz oob boost is certainly on the higher end of the 780 scale though.
As Matt said though maybe its down to the drivers you're on, haven't read much into the latest amd betas but I do remember some saying the previous mantle betas had a negative effect on DX.
Yeah mine comes in three mode's and can switch on the fly Quite mode 947 gaming mode 977 and OC mode 1007
Yeah i didn't think there was a performance drop in DX on 14.2, but looking at those scores there might be. The problem is 14.2 also has a bug with powertune so its possible that somehow that could have something to do with it. Test 13.12 WHQL if you get time shanks for a comparison.
Those are some stingy overclocks msi lol.
Might get 13,12 installed later or tomorrow. its having the time. but now that I have started something I think I after finish it.![]()
