- 17 Oct 2005
- North of Watford Gap
Edit: Obviously choice made, so much of the below is irrelevant.
I wouldn't bet on the battery life being better on the Note 3. While the Note 3 obviously has a bigger battery, everyone seems to be raving about the battery life on the M8 - presumably a combination of software tweaks and Snappy 801 optimisations.
Obviously the plus points of the Note 3 are the pen and the bigger screen while not being that much bigger than the M8.
The M8 though has those speakers, the perceived built quality and associated looks, and doesn't have Touchwiz (which seems to get vastly worse with every passing day).
Personally, I'd snap up the M8 over the N3 in a heartbeat, and would have done had I not just bought a Nexus 5 on release.
It all comes down to personal preference here to be honest, I'd say in real life usage you won't see much different in terms of power. Battery life is going to be better on the Note 3, Camera I would say the Note 3 would take better day shots, HTC better low light shots. There is more RAM on the Note 3 for better multitasking but then again I dont think that'd be an issue on the HTC anyways.
I'd say have a play with both first, you can't go wrong with either one.
