- 25 Nov 2011
- The KOP
I use a sound card so not sure that's the issue but worth a try.
I just tried taking screenshots in the game using the printscreen button on my keyboard but it just took a screenshot of the desktop... could that be related to this issue perhaps?
Now that is interesting. I would start disabling all apps not needed and see if something else is stopping it.
When you use mantle in fullscreen and you use print screen to take screenshots does it take a picture of the game?
No but it should take a black screen and not your desktop.
Matt does RenderDevice.FramePacingMethod do anything for single GPUs? if so which one?
It does, it works on single gpu's as well. I recommend trying them all and using which one works best for you. If it was me id probably disable it if i had a single gpu to garner all the fps i can get.
Ok thanks. another excuse for some messing about.
ERROR
Game disconnected: you were kicked by PunkBuster. Stated reason: PunkBuster kicked player 'pgi947' (for 0 minutes) ... RESTRICTION: Disallowed Program/Driver [130827]
Any clues as to whats caused this?
Purest of pure clean installs of windows 8 on sunday, drivers installed along with steam/origin and relative games THATS IT.
Cheers fellas, all done.
Never had that from an out of date PB file before, usually it just doesn't let me join a server!
