Yes, i found it on Reddit, and even i posted that i'd tried that, but the config doesnt "fix" the fact that the game believes the Stick is the Throttle, and the Throttle is the Stick. So?X55 owners the config "fix" has been in OP since yesterday. Tut tut![]()
Cheers, i'll give that a go. I wasnt sure if this was the throttle issue people were talking about, cos i hadnt seen anyone suggesting remove the whole throttle device to play it. I definitely swapped their USB around wondering if there was some order priority (i know there shouldnt be) but hoping it'd somehow convince it otherwise, but nothing helped until i fired the launcher up with just the stick connected.Fellow X55 owner here your spinning could be Joystick order try removing drivers then swapping USB ports as you want Joystick first in list, dumb I know but that worked for me.
If that dont work Google search removing Axis profiles will be Vid.cfg or something. then recalibrate in windows.
Finally have put a link on Pagan to get X55 working once you followed the setup you got fully working X55
I definitely need to use something to mount it though, i bought a roll of the rubber grip mat stuff, its fine but i felt like with so much movement and twisting i needed to hold the base down, ive got some long enough wood screws and i'll do a shabby job of clamping it to some bits of wood under the Obutto HOTAS mount as its thin steal which is smaller than the screw-hole dimensions.
I've been trying to think of a long term solution, cos i just dont fancy velcro tbh.
