Woodsta i posted that colour file for you in the monitor section.![]()
Anyone having issues with the display ports?
I have a monitor with speakers so liked using the DP cable however recently i've noticed that CCC pops up an error
I only have a resolution option of 1024x768 then and other times the screen refuses to come on at all until I switch to DVI.
Monitor is this http://www.overclockers.co.uk/showproduct.php?prodid=MO-063-AS&groupid=17&catid=1120
You've run the 799 on it's own though you'll still need Xfire on to run just the 7990 as it's a dual card. I see you are running 3 monitoirs too. Tried 1 monitor?
Could be an eyefinity issue. I Never used eyefinity so couldnt help but I remeber eyefinity can be problematic.
Were you always running 14.9's? Did the problem manifest after a driver change?
Can understand your frustration as it has been working.
Quick google and sounds like another piece of software is conflicting with the game. I'd run a malware prog such as spybot search and destroy. Which anti virus are you using?
Hi,
I'd have to google error code myself to look it up.
Norton!!!!!!!!!!! Take that rubbish off. That conflicts with everything. You dont need to pay for a decent anti virus or malware. Norton is the worst of the lot. I'd start with removing that. Use a decent Driver uninstaller like DDU (display driver uninstaller) and reinstall drivers.
