Don't know if that helps you at all but hopefully it does![]()
Yeah it does cheers
Also on a side note, started using the stock browser after reading this thread and have to say I like it a lot.
Weird, mine seems to report on the town I'm in, with or without GPS, do you get the same problem with the BBC weather app?
Yea BBC weather app and everything else reports my exact location fine, but the HTC one doesn't and just states south yorkshire, while not a massive problem it's kind of annoying.
Yeah it does cheersthink I'm gonna go for the barely there case, looking for one that doesn't add much bulk so sounds good. Don't think I've had a case on any of my phones yet that doesn't allow some sort of dust or dirt into it somewhere.
Where is the cheapest place for sim free at the moment?
Does anyone know how to move apps, specially Spotify and its data (music) to the SD card? I have tried deleting the spotify cache, all of its data and totally uninstalling it but all downloads are still being put on the internal storage instead of the SD card.![]()
My One S is the same gen as an S3- I had the choice between a One S / galaxy s2 or a One X / Galaxy S3. its got a 1.5GHz dual core and 4.3" screen. Maybe I'm just hard to please![]()
Well I managed to get GPE on my HTC One M8...with no end of hassle, tried not to root etc and managed to manually install but will sort out the full process and do it again.
Basically my mobile banking app doesn't do rooted so had to go the unrooted route.
I ended up installing all the files manually and individually which took some time but appears to actually have worked.
Phone seems to be that bit snappier on GPE than compared to sense...will stick with this and see how I get on from here![]()
No help now, but this guys videos I found brilliant for rooting... what does GPE do for you aside from getting latest update?
http://www.youtube.com/watch?v=WEouT7eV8UA&list=PLHTorDR_h9wzlSNE_Ewoy6LpjXrTiEo3F
