- 28 Apr 2013
- Edinburgh
Just to let you guys now that EK is going to make blocks for MSI 970
i'm not being funny or anything, but you do realise that the 970 doesn't need water !!!!!!!!!!!!!!!!!
My Msi turned up. For a laugh I set 1580 on core. Works perfectly and temp hitting 61 degree. OMFG. What a card.
It does if you want it to run in silence, I can't stand noise![]()
Leave heaven looping for a while when you can or just play some games for a lengthy period. Certain games will work fine others will probably crash at those clocks. Diablo 3 seems to hate an overclock, can play for 2 hours and it will be fine, then go on the next day and get a driver reset within half an hour. Games like BF4, ARMA 3 and Planetside 2 don't crash at all.
To be honest Diablo 3 doesn't even need an overclock so I may just switch to stock clocks while playing that, could also be the fact of new drivers on a new card but I'd have to check if other people have had crashes on 9 series cards. Max bench stable and max game stable can sometimes be a fair distance apart.
I noticed that too, I was slightly higher for benching so I drop very slightly to the speeds above. I will keep an eye on temps then drop if needed.
People have said by adding more volts has not helped the OC's so i haven't bothered.
MSI is +87
So you can hit 1580 thenthat's nothing to moan about if it's stable in gaming.
I think there's a few of us who want to push for more but even if we can't that's a lot of performance for the money, above a stock 980.
