Permabanned
- 15 Dec 2008
Still can't, I'm IP banned.
Post exact link to the file you want here and I will host if for you.
http://www.overclock.net/t/1517316/...ware-nolimits-and-gamestable/80#post_23037661
The file from post #85 if you can please
Basically I need NVFlash that can Bypass the checks and the latest BIOS Editor, think it's version 1.36 Beta?
Was going to buy two 970s then realised my mobo doesn't support slialso g1 970 won't fit in my case, the £ all adding up!
Get yourself either an MSI or Asus, both are nice cards and shout fit in your case. You can always replace your mobo and buy a second card somewhere down the road if you feel like you'll need more horsepower.
Only running 1080p at the moment so won't need to SLI right now, but thinking about moving to 1400p in the future, will a single MSI be okay or would I need two?
344.80 drivers available which has a fix for anyone having issues with displayport. I haven't tried them yet myself, but will have a go this evening:
http://nvidia.custhelp.com/app/answers/detail/a_id/3607
I've put these on. But I still have DP issue, ie. once I've uninstalled nvidia drivers with driver cleaner, when I boot to windows my monitor doesn't work. Luckily I have another monitor on DVI, which does work. Seems silly if you only had a DP monitor. How would you do anything?!?!
Gigabyte GTX 970 G1 1560/1753 (CUSTOM BIOS)
