Looks like it's stellar: http://community.pcgamingwiki.com/p...-report-metal-gear-solid-v-ground-zeroes-r168
Well that's me buying this I suppose!
Some things to note about the minimum and recommended specs; first is that a quad core is recommended even at the lowest level. This is because the game is brilliantly multi-threaded using my 8 cores almost perfectly evenly. This works out for everyone, for Intel users with their higher performance quadcores and AMD users with their lower performance hexa/octocores.
Secondly, DirectX11 is required. While there are no features like tessellation or HDAO (at least not specified in the options menu), this may mean some people might not be able to play MGS straight off the bat and will need to upgrade. Make sure your card is compatible before purchasing the game to avoid disappointment.
Thirdly, the 4GB VRAM requirement on the minimum is almost definitely a mistake on their behalf. During my tests, just over 2GB VRAM was being used at the highest settings at 4k. On top of that, the memory usage of the game hovered very closely to an incredibly lean 1GB of RAM, so 4GB should be totally fine.
3gb? MGS4 was like 50gb on ps3 wasnt it? Is that definitely the full game?
