Metal Gear Solid: Ground Zeroes coming to PC!?
Looks like it's stellar: http://community.pcgamingwiki.com/p...-report-metal-gear-solid-v-ground-zeroes-r168
Some things to note about the minimum and recommended specs; first is that a quad core is recommended even at the lowest level. This is because the game is brilliantly multi-threaded using my 8 cores almost perfectly evenly. This works out for everyone, for Intel users with their higher performance quadcores and AMD users with their lower performance hexa/octocores.
Secondly, DirectX11 is required. While there are no features like tessellation or HDAO (at least not specified in the options menu), this may mean some people might not be able to play MGS straight off the bat and will need to upgrade. Make sure your card is compatible before purchasing the game to avoid disappointment.
Thirdly, the 4GB VRAM requirement on the minimum is almost definitely a mistake on their behalf. During my tests, just over 2GB VRAM was being used at the highest settings at 4k. On top of that, the memory usage of the game hovered very closely to an incredibly lean 1GB of RAM, so 4GB should be totally fine.
Well that's me buying this I suppose!
Guys check the link I posted earlier... That guy did the testing and it boils down to Kojima's folks most likely mislabelling that spec, the game uses nowhere near that 4GB.
The game is very short, I have it on PS4 and played it to death. It's still very good and will appeal to fans of the series. Newcomers might moan it's very short but that's the point, it's a taster to the phantom pain later next year.
Expect the whackiness of Kojima's story telling mixed in with the tactical espionage gameplay. It's a great little game to max out by completing all the objectives/achievements but don't expect lots and lots of content from what is essentially a polished tech demo / prequel type thing. For £11 quid it's not going to break the bank.
EDIT: I'm such an MGS geek I doubled dipped with Ground Zeroes on PS4. I have the English spoken Keifer Sutherland version and the import Japanese spoken with English subtitles version.
Fed up with reading that. Numerous people report that this holds it's own as a standalone game, even though it's just over 2 hours on a first play through.
I quite happily pay £11 to see a 90 minute film at the cinema. £11 for 2 hours of Metal Gear is value in my eyes.
You can complete it in 10mins, its a demo either way you look at it..
mrk iv heard its not working properly on 21:9 yet it zooms in.
Think ill wait till that's fixed first before I give this a try.
If I can load the Steam Store to get the damn thing I could let you know haha!
