Well, it looks like I'm going TriFire! Picked up a Lightning LE 290X in the MM for £205
Good man.
It'll do until I can find another well-priced 295x2![]()
95% done. One of my red leds I bought from overclockers broke, so will order one or two more then I think I'm finished.
Going to call it The Red Baron.
Love itfew questions mate please.
First of, @ 4k, how much Ram is the cards using in BF4? As i've not tried 4K yet (wating for good monitor to come out with Free sync) if over 4meg, with there be problems? what settings in BF4 you using for 4K.
2nd, Them fans you're using. what are you running them off? the cards 4pin wire with a y splitter? they running well mate ?
Cheers
Called mine, The Radeon Lightning
4K BF4 Mantle uses more than 4GB, so if you have 4GB cards you'll need to disable AA or use high texture with x4 AA.
8Gb 290X cards run it maxed out without issue, uses about 5gb in Mantle.
I tried using a fan splitter, but neither fan worked. Not sure if it was not enough power or the fan splitter was just crap. The fan splitter had one three pin and one two pin, so not sure if that was too blame or the Noctua Industrial 2,000 rpm fans were too much for the 295x2 header.
In the end i connected the fans to my fan controller.
Very nice.![]()
Thanks.
Do you see much difference using high texture with x4 AA, compared to ultra texture with x4 AA @4k
Would you recommend them fans ?
Currently working on undervolting both 295x2's. Tried them at -0.100v and almost stable. Crashed with a driver error after 20 minutes of Cloud Gate. Retesting now with -0.094v, think either this of -0.090v will be stable. That's some undervolt!
@Smrtka
Undervolting is basically lowering the voltage of the gpu below stock settings, which means it uses less power and runs cooler as a result.
