- 20 Jun 2011
- Livingston
Good points about EVGA. Worth paying a bit extra for the customer service, warranty, step up and resale value.
No just wondering, some nice clock speeds. What are you testing for stability with and how exactly are you changing the voltage/power limits?
Ah, so it fits OK? Think I'll just pull the trigger, unfortunately the back plate is out of stock so might need to source elsewhere.
** Edit **
Also, will your stock back plate go back on if needs be? I assume it was just fixed with screws as normal?
Is msi afterburner the best program to use to overclock a galax 980?
Well that's the waterblock/backplate fitted.
The bare card
Quite a lot of unnecessary stock goop on the gpu. Not good!
All cleaned up
That's better with all that crud taken off. Rest assured I did a better job of reapplying than Gigabyte. I used MX4.
In it's natural habitat
Currently idling at 27c / load 40c
Now to get around overclocking this properly. . .
Yes it is - so should go back on with the wb.
Mark
Yes... that or EVGA Precision X really... I'm not sure which I prefer yet, only just started using the EVGA software.
Woo... bumped myself up to 5th place on air
for the other type of mem, you should make +500 easily.
I had 2 970s and now a 980, all had Samsung memory and wouldn't go much above +300. Is memory OC susceptible to voltage?
Few questions;
What's the normal idle temp of a strix?
I presume the 3dMark physics tests are a CPU test, and physx is not used?
Am I correct in saying a G3258 would be a significant bottleneck to 3dmark scores when paired with a 980?
 2015-02-17_13-10-06 by CosmicLogos, on Flickr
2015-02-17_13-10-06 by CosmicLogos, on FlickrAm I correct in saying a G3258 would be a significant bottleneck to 3dmark scores when paired with a 980?
	I've just switched back to MSI Afterburner... after a bit of testing, I think it's a bit better.
It depends on which memory you have.
+100 core
+250 mem
will likely work fine on most cards... maybe a little voltage boost (under +50mV)
