Well my GPU is on it's way back to OCUK for a full refund, not sure which one to get though, not going for the SOC again![]()
I have the samsung memory, here are the settings that I have applied at the moment.
do they look ok or shall i go higher on the memory? i have the kfa2 soc 980
Ta. thanks for the curve. Idling at 40c stock and thought this was high, but it seems not.
I was thinking about one of these :
http://www.overclockers.co.uk/showproduct.php?prodid=GX-261-EA&groupid=701&catid=1914&subcat=1812
Are they any good?
I went for the EVGA SC card in the end.Well my GPU is on it's way back to OCUK for a full refund, not sure which one to get though, not going for the SOC again![]()
Should I rub it in that I got mine 20% cheaper? mwuahahahaaaaaa
Good cards, definitely... but I highly recommend a custom fan profile.
I need to find an alternative source for the WF3 back plate as OCUK aren't ordering in for any time soon. Anyone got any suggestions for an alternative UK based supplier? The "special" supplier doesn't have any, and I've Scanned other suppliers...
1 x EK Water Blocks EK-FC980 GTX WF3 Backplate - Black £22.49
what was wrong with yours neil? could you shed any light on my settings since you previously had the same card as me?
I've just had an RMA authorised for mine too. Not sure what to go with either.
Pyr0m@nI@]{;27643429 said:I went for the EVGA SC card in the end.
It runs much quieter and cooler than the SOC I had
With a custom fan profile, it idles at around 28-30C with fans stopped and into the 60's under load
Try +500 of mem then run a couple of benchmarks... see what happens
40 is good![]()
Glad I ordered mine when I did!![]()
So that's a choice of
EVGA 980 GTX
OcUK ref 980 GTX
Get the cheaper OCUK version, it will clock to and well beyond the EVGA version.
I agree, just waiting for the price to come back down a little as it was on sale before but just missed it![]()
