AMD Radeon R9 295X2 Owners Thread
This is what you want mate. Will give you headroom for a second 295x2 at a later date.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-010-SF&groupid=701&catid=123&subcat=2464
If that's out of your price range then one of these should do it for a single 295x2. (and maybe enough for 2x295 but it will be right on the limit)
http://www.overclockers.co.uk/showproduct.php?prodid=CA-009-SF&groupid=701&catid=123&subcat=2465
They also light white? :O
Sorry I know this isn't the thread for it but is the difference between the gold and the platinum versions please?
i run my 295x2 from an ocz 1250 watt and the coilwhine was pretty bad when running both cables from the same rail.
I have since changed to a rail per 8 pin cable and have not noticed it as bad but then i aint gamed much since either as i had to reinstall windows and lost my save games......:mad:
Thanks for the confirmation.
Might be worth a shot at a new PSU Watling. :)
Ahhhhhh OCZ, reinforcing their reputation in new ways every day ;) :D
ie ****
Mmm, sweet setup. So, have you had problems running BF4? Mine used to run superb in Mantle in quad 7990's BUT hadn't played for a while and the game is screwed now on quad setup... however, I do fancy two of the 295's for a while until the new stuff comes out... and wondering whether to bother. My new 295 comes Monday... will see how it run's. I'm on 5760x1080 eyefinity btw... worth quad in your expert opinion?
I'll let you be the judge of that by watching my 295x2 QuadFire setup run BF4 at 1080P.
You can expect a big performance boost when running in full screen mode and not recording at the same time too. :)
im running 1 295x2 using eyefinity 7860x1140 and is sweet. you wont really need quad.
Cheers guys can't wait for this actually quite excited. One of my 7990's is now up on a certain site for sale... new 295 is delivered Monday will see what she's like. Time to get 3DMark out again lol
I have a Super flower 1200w platinum. Guess you might get away with 1000w PSU though.
Top card is 295x2 so everything is plugged in to that.
Hmm tempting...something to write santa to, 4k 144hz freesync + 290x pls i was good santa :D
*typo I meant satan...
GPUCool backplates from overclock.net
I've got the LEDs hooked up to a Grid+, so they don't light up until the GPUs come under load.
