It will be dude they're made of cheese, very soft. Stick an OEM one on if you're not a racecar kinda driver. Tightens things up and still keeps vibrations to a minimum as they should be on a road car
I had a Fiesta ST sold last year and as a ballpark figure I paid £375 parts and labour with a motorsport company for:
Gearbox oil change (Castrol 75/90), PAS fluid change (Castrol Dex III), Motul 600RBF brake and clutch fluid change, Pagid rear discs and pads, Front ARB drop links, Lower engine/gearbox dogbone mount, strip and clean brakes and calipers, grease gear linkages, check clutch noise and advise, re-fit exhaust sort blows and hang it properly, full check of suspension, bushes, general car check over for advice.
Yes I am sad and kept a diary of money spent lol.
