- 14 Nov 2006
- UK
getting annoyed with my xbox one
it just becomes unresponsive every other day and i have to hard reset
it will be sitting at the dashboard, but you cannot load anything, no games, apps, or settings. you can press A and it makes a noise but nothing happens
then when you turn it off with the controller the console X slowly flashes for several minutes before finally turning off
Mine does the same thing more often than I'd like. I've just been doing a hard reset - really annoying though. I've read that Microsoft is aware of the problem and are looking at what causes it. There is survey about it this month on the preview app I think.
Reading about on reddit and stuff suggest it might be the instant on mode playing up. I think I'll try turning that off as Gord suggested!
