- 8 Jan 2009
- Northern Ireland
At long last, MS is updating from build 10130 to build 10240, with the promise of more updates over the next 2 weeks.
updated via windows update and then went to device manger and clicked update and then chose the install folder for the newer drivers and they seemed to installI have that problem. Rather annoyed. I take out graphic card and use onboard Intel graphic card and Windows 10 install sucessful then put the graphic card back in and all went ok.
How do I get a valid license ? My Laptop had 8.1 installed and I registered for the insider program when it first came out and have tried a few builds. I had the little flag in 8.1 on the task bar.
Will I need to re-install it back to 8.1 and update on the 29th ?
The final version of Windows 10 won't have a "key logger".
What codecs are people using with win10, I have some old avi and flv style movie files that will not play under the base install, so what are people using to adjunct the basic installation?
I tried to install the preview, but it asked for drivers right at the beginning, and I didn't get any further. I'm guessing this could have been for the NVidia RAID array, has anyone had this ? I'll probably need to disable the array.
and it works(so far)I had something similar with Intel RAID. Even if you've only got one disk, if it's running under RAID mode in the BIOS, you will need to supply a disk/usb with the RAID drivers. If you don't you can get weird things happening.
With a Win 7 re-install from scratch I did recently, the install could see the drives and do an install, only to fail at the end saying it couldn't run Windows on the hardware. It needed the RAID drivers at the beginning to complete the install successfully.
Hi there
I've just installed Windows 10 RTM on a spare SSD and it's working all fine.
I did not enter any windows key and just pressed skip to get the install going.
I have done the reserve windows 10 update procedure prior to doing this (weeks ago).
Is it OK to enter my retail windows 8.1 pro key now?
Your Windows 8.1 key will not work. You need to upgrade from within 8.1 for it to activate.
people complain about key loggers yet want to use a feature that MS discontinued because of serious vunerabilities. Makes perfect sense...
Yeah...no. Wont catch me using gadgets.
