For those who have pre loaded, what did you do to pre load?
Did it automatically prompt when turning on the pc or did you open the windows reservation button in the tray and it prompted from there?
So I've applied for the free upgrade on a few machines.. Will I get a key for each one? How does it work?
If I was to do an upgrade from the RTM link above then a clean install afterwards would that still work with the insider program not taking on new PCs?
It worked for me though I was registered with the insider program before they stopped accepting new PCs but I didn't actually do the upgrade till after they stopped.
you don't get keys..
Its an upgrade so your old windows installation + key gets updated to windows 10.
How do you fresh install? I never use upgrade installs.
