Took me about 3 mins to download!I'm amazed people are having download problems. I read an article quoted on Reddit that Microsoft had paid for a dedicated bandwidth pipe of up to 40Tb/sec.
Can I now delete my windows.old folder?
Yes, if you're happy and don't want to roll back. Delete it through system cleanup is easiest.
If you upgraded from a retail copy of Windows you will be able to instal in the future if you upgrade your PC. If you upgraded from OEM version of Windows you will not be allowed to instal it on a new build.
disk cleanup?
I understand that part, but what i don't understand is that if we upgrade from 8.1 to 10 on a retail copy of 8.1, do we get a key that's specific to windows 10 or do we forever have to install 8.1 and then upgrade every time we get new hardware so that the unique ID of the hardware is valid?
Win 10 OS is no better than Win 8.1I am sticking with Win 7 that's almost perfect MS need to do a lot more on UI design its horrendous on 10 no better than 8.1. Still no Aero either which is bewildering! Tiles are also a dead end UI wise. MS should just go back to the drawing board again this OS is trying to be for all devices it does not really do anything better than 7 for Desktop's.
I am struggling to think why MS are even persisting with the Tiles UI on a desktop
At least its free if you need an OS..........
Not the most successful of mornings - ran the install but it died half way through with a 0x800700c - 0x40000d The installation failed in the SECOND_BOOT phase with an error during the MIGRATE_DATA operation.
A second attempt & a google later & I tried again this time with no AV, unplugging USB devices & network cable via an ISO image & not keeping my applications and it worked!
Only to bring more problems, it seems the Atheros AR8161 PCI network drivers from my Gigabyte SKT 1155 Z77-DS3H motherboard don't work on Windows 10 and there are no updated ones. Any ideas folks? In the meantime I've rolled back & at least I have my applications again.
My product key does not workDoesn't give me an option to phone or anything.
I upgraded from Windows 8.1 Pro Retail but did not do an upgrade just did a clean install
Help
Help
Help
