Anyone on here got a Collins Quickshift fitted on their MK2 Focus ST's? What do you think about them if so? I've just ordered one as Phil W reminded me Collins have them on silly cheap offer. So, wondering what they do/if they are a worthy addition.
Can you recommend some quality ones then?
The chrome caps come of even when using a normal wrench
Guys I'm considering buying a 14/15 focus St 2/3 in the next 12 months when i sort my bills out. Is there any issues with it using a Dual Mass flywheel? Has the reliability improved in Ford's in recent times? I did used to have a focus many years ago but since moved onto Jap cars.
Thanks in advance..
Haven't heard of any ST owners having problems with the DMF. If you're going to be modding you'll probably end up swapping it out when doing the RS clutch like I have.
Yea I got one too, £30 from Collins, KMS is still doing them at £45. Collins was meant to be an August offer but they ended it after one day. I guess they weren't prepared for such a response!
Jamous: Join various tuner companies as well as Focus related Facebook pages. You will know instantly when deals are on![]()
Just picked up some RS Injectors for £100. Score. CP340 is underway!![]()
Been looking at these recently, meant to help at most levels of tune.
Hi ubern00b,
Those replacement a/c knobs how did you find their fit.
I just fitted mine and not happy with how they sit.
They don't sit back into the dash enough so i can see the lights coming out around them.
