It's amazing how quickly the 500GB is going though - I have a digital copy of Forza 5 (free with the console) and Ryse (always fancied playing it), along with a disc version of FH2 - and I'm sat at ~40% HD space goneI take it that you can't just sling any old drive into an xbone?
Also the performance of loading times increase when installed to a external HDD compared to the internal (weird I know).
On the PS4 I can't even update Game X if Game Y is open and running, plus there's no functionality for snapping 2 apps together and running them alongside each other..
You can plug in an external HDD via USB no problem, I stuck a 3TB drive on mine.
You need a external USB 3.0 HDD, pop that round the back and let the Xbox One do the rest. I'm picking up a Samsung 2tb later for my console as it nearly full and I hardily have any games.
Sure about that? I was playing Planetside 2 last night, and i'm pretty sure the Witcher 3 and War Thunder were updating in the background. I got notifications to that effect anyway..
Nope, not for me anyway and my console is always in Rest Mode also.
I started it up, noticed there were a load of updates waiting to install so tried to do them manually from the notifications panel and they insisted that F12015 which was running in the background was closed first. F12015 wasn't even one requiring an update either!
Are you saying its better loading speeds off the external drive?
Whats a decent drive for the XB1? Any recommendations?
Great find. Just did this and there was a noticeable upgrade in visual quality even over the high setting. It's almost like the console is plugged directly into the screen you are streaming to now, any compression is virtually gone. The slight fuzziness around edges doesn't seem to exist any more. Weird why they didn't unlock this as standard. PS4 streaming to a local PSTV box looks terrible now in comparison.
For info. for anyone else doing this though, I navigated to the folder but I think they missed out "\LocalState" off the end of the path in their instructions - that's where my config file was anyway.
You have the Kinectless version I take it?
have fibre with 40meg d/l and 11 upload![]()
As long as game streaming is enabled on the XO then there isn't really anything else to configure. It should just work from the W10 app.
What does the network page on the console itself say, is NAT open or strict etc.?
Heard from folks who had some massive lag problems was cured by switching off location services in windows
