So I've ordered some from Amazon via the thread on focusstoc.com which recommended the steel capped solid nuts.
Your map has to support the injectors or it will just overfuel and your MPG figures will be all wrong. I know REVO doesn't support uprated injectors and Collins CP320 and below do not either.
Collins do a version of the CP320 map to run with RS injectors - that's what I'm running in mine, though in truth there is no benefit to running the RS injectors with that particular map - I mainly went to the RS injectors for peace of mind and it was early days for the Collins maps at that time.
What other kit is needed (or supplied) for the CP340 apart from the RS injectors, is it a turbo upgrade too?
Not having a good few weeks with mine. In the last three weeks or so I've had a cracked windscreen, a puncture, and someone's shunted me at traffic lights![]()
7.15am this morning I too was shunted at traffic lights.
Guy jumped a red light but I walked away from this:
Gutted![]()
Whoa, main thing is you walked away!
Have you called Mors Mutal?![]()
Linky? Either to Amazon or focusstoc. Thanks![]()
http://www.amazon.co.uk/gp/product/B00DO0H1H8?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
I bought from PE16 Car Parts seller, as that was the eBay link that was posted on focusstoc
Doesn't say what material they're made out of apart from that it's not steel? I'd be wary of them,
I think the 'Not Steel' comment in the advert refers to using them on alloys rather than steel wheels?
I'll repost my checklist again if it helps - Click Here.
