xbox one doesn't support USB headsets?
wtf is up with that? why does it have so many usb ports?
cannot believe you need a wire from the controller. not a huge issue but shocked they don't support usb headsets.
Can anybody tell me if a 360 headset will work with the new controller if I simply bought a cheapo, standard 3.5mm male to 2.5mm female adapter?
Like this,
http://www.ebay.co.uk/itm/3-5mm-Jac...094439?hash=item3f235ad2e7:g:syEAAOxyGqZSaEOQ
Or could anyone suggest an alternative other than buying a new headset or paying £20 for the official Microsoft adapter?
which means plug and play usb like the ps4 isn't supported. it doesn't detect my mixamp as a headset so requires the chat cable.
It is supported, but not on your mixamp. You need the Astro TR mixamp (white) specifically for XB1 if you wan't USB voice/chat.
Decided to try out a Skin to see hwo it would look, not sure on it to be honest...was maddening to fit on exactly.
Does the skin hide dust better than the glossy surface?
I own a pair of Chinchillas and the dusting is never ending but to have to dust daily is just a little crazy now.
I bet applying that was fun
