What a peculiar thing to say.I see nothing wrong with the monitor and if there is then I can live with it.
My 42" TV has this same problem in dark/black scenes, because the actual panel is bent in all 4 corners...
Thank you for your e-mail.
In response, please note that this a drawback of the technology and it won't be covered by the warranty. I would advise taking it back to the retailer for an exchange.
However, if you want to keep the unit, Panasonic UK does not recommend that customers attempt their own repairs. Instead, we suggest that the product is submitted to an authorised service agent for attention. Those in your local area can be found through our website: http://www.panasonic.com/uk/support.html
I trust that the above information will be of assistance to you. However, of course, if you should have any further queries, please do not hesitate to contact us.
Kind Regards,
Alexis
Customer Service Team
Panasonic UK
To thos with the monitor, can you do a test for me?
If I put my index lightly on the bottom left corner, the panel doesn't feel attached, and I can see the glow there disappear when I do so.
Its like the coating or whatever plastic thing is between the panel and coating isnt flat, I noticed a similar thing at the bottom right, but had to use a hint of force there. Pushing it got rid of glow completely, but as you let it go it comes back.
Can you slide a thin piece of card between the panel and frame to cure it?
I cant get my Xperia Z3 Compact to show what I actually see.
Photo:
Screengrab of video:
On photos the glow on the right looks like its reddish but to my eyes its silvery/grey.
Left side is blueish but not noticable during darker content, to my eyes.
Right corner is a bit annoying though as black turns silver and detail is lost.
Theres no BLB, if I move head to the right (and vice versa) where my right eye is almost at bezel, the glow there is completely gone and theres no other light coming out.
Also the coating makes dark content more annoying, as you can see yourself in the monitor.
Is it worth upgrading from my TN PG278Q ROG Swift to this IPS one ?..![]()
Depends if you get a good one with little BLB
Depends if viewing angles are important to you...
Depends if you can live with IPS glow
Monitor tech currently is stuck in the dark ages...it's not moved on really very much...
Those pictures just look like normal IPS glow, nothing to be done about it. Silvery/orangy glow on the right and blue glow on the left is pretty standard. Unless you sit really far back from your monitor and dead on to it looking at the centre of the screen it's gonna happen.
Problem is if I press on the panel the glow disappears, especially at the bottom left. I can feel the panel is a bit loose there.
That sounds like horrible QC
I am having a hard time trying to decide whether to get this monitor (from a different seller) or hold off till something better comes around. Regardless of the poor quality control, is this monitor a significant and worthwhile upgrade from a standard 1080p 60hz screen?
Due more stock this week fingers crossed.![]()
