- 23 Mar 2011
Thanks for all the advice cheers!!
Also technically, how does this game run on a gtx970?
4690k @4.5 gtx 970 no overclock, 16gb ram and everything set to ultraThanks for all the advice cheers!!
just use default settings
should be fine.
for those thinking of getting and get a refund . try a good car in custom (custom you can try all cars on all tracks ). something easy to drive like a 2010 fiesta rs or volkswagen polo.this game isnt like the other dirt games. you have to learn.
what wheel you got ? g27
i always used same on mine so for me it was easy.logitech default and tweaked ingame.
try 200-540 degrees rotation all stock settings in logi profile make sure centering on. allow game to change tick box
ingame adjust tourqe alignment to say 20 maybe ten
make sure soft lock it off ingame.
