It is very unlikely than any manufacturer would test cards under load, normally the testing/inspection would be a combination of AOI, ICT, flying probe etc. Any form of inspection and testing can add considerable cost to a product.
mines been sent back and refund given. waiting for the funds to appear then will plan my next move
I won't accept anything other than complete satisfaction.
Dare I ask what "complete satisfaction" involves ?
 Just a replacement or full refund will do.OcUK have confirmed that the GPU is faulty. They are issuing a replacement, but they haven't specified when! I hope it's not **B Grade** or something. They don't appear to have many in stock, if at all.![]()
I doubt you'll be sent a B Grade card.
Simply check the packaging, the box should be sealed.
And try to stop worrying, it'll make no difference to the outcome (which is highly likely that you'll have a brand new working card).
Having said that, you do know that apparently the fans on the card always run, despite the specifications claiming that they stop when the temp is less than 50C ?
I'm a worrier. It's probably why I'm bald!
I didn't know that, no. It's not a major deal breaker, as long as the darned thing functions this time!
Edit: Finally been sent some tracking info. Should be here tomorrow. Saints be praised!
Good. I'm sure you'll let us know how you get on with the replacement.
To be honest, the fans running constantly is not really a problem, and I doubt you'll be able to hear them. The fans on my Gamerock Premium sometimes start up, even when I'm not running any 3D apps (in warmer weather). When they do start up, I hear a very slight "click". It would probably be better if they were running constantly.
Was about to order a 1070 Jetstream. Think I'm going to hold off until there's more info.
Why has this feature been omitted from the version I have? Do you have a source btw?
Quick question....
Running a Palit GTX Dual 1070 here. Should the fans drop to zero ?
The min speed they ever get to is 1000rpm.
Do I need to use the thundermaster utility to manually override the fan settings, or should it do it out of the box ?
*EDIT* Just installed the thundermaster utility - the minimum fan setting appears to be 32% which is about 1000 rpm - hmmm ?
someone with over 9000 posts asking if you live on social media..the irony![]()
Social media behaviour is totally different to a forum.
