re 980 970 Really ? i owned both , remind me which card was borked again?
Do you mean the incredibly successful card that was perfectly pitched at its intended resolution with more than enough vram (overkill really) for its intended use ?
Keeping my 1080 till games struggle at 1440p, can't see that happening anytime soon.
Pretty big gap in performance between the GTX 1080 and Titan XP (the GTX x80 Ti is usually just a cheaper version of the Titan X).
I use both and for most things either will do.
To get the most out of the Pascal Titan (and the up coming 1080 Ti) you have to fit waterblocks. If you don't with the 1080 Ti (or you have a very good AIB partner cooling solution) you will be hard pressed to tell the difference compared to a fast 1080.
Having said that my Pascal Titan PC is a beast.
4 way SLI
2 x 1500 watt PSUs
2 x 420mm Rads
6950X
Watercooled and totally silent apart from the water pump. The fans on the PSUs don't have to run even with everything overclocked.![]()
Hows 4 way support on the Titan Xp kaap? Is it still gettin supported?
This ^100%.
If your on the 1080 there is no need what so ever for Ti. If you want to waste money wait until 11 series. That won't be long before released. 1080Ti=Money Grab
the x80 and Titan cards are the money grab cards historically, x80 cards are normally priced much higher for not much more perf over the x70 cards. For the money the Ti's have been pretty decent in performance since they last a long time.
This ^100%.
It is actually the x80 Ti card that is the money grab card as it comes with a higher price than the x80 cards.
Titans as a long term investment are petty good as the extra memory gives them a very long service life. You can still use the original Titans as they had 6gb of memory, everything else from that era won't run the latest games.
20% Better than a Titan XP? Cor blimey, I don't think we'll see that till the 110 series. Now who demanded that big of a boost? I reckon a 5-10% bonus should be good enough perhaps, considering how close Titan XP get's to 4k60.
Borked? What borked. It's just 3.5GB VRAM is all(even though they misadvertised it and messed up there)
Maybe you're right. But I'm eager to be off these bad Nvidia drivers, so I'm banking on Vega not being a disappointment. Either that or a fresh new (1080ti?) Nvidia GPU, maybe it's my 970 that is the issue?
Not sure why I opened this thread to find useful info... Predictable strange claims and product rubbishing as always. I'm not gonna lie i'll be tempted to jump from my 1080s but we will see how the price/card stacks up.
Aint gonna be better than the Titan, no logic there... Potentially 'close' for some extreme overclocks but the TXP seems to be an absolute beast.
Other than that Linkedin leak, is there anything at all solid about this card?
Whatever NVidia decide to do, the only thing we can be certain of, is it will be faster than the 1080.
I believe it will be faster than TXP.
But what worries me is the price they'll charge for it,
