*** Official Ryzen Owners Thread ***
why do you need to send back the hero boards? mine here is working eyetrip has the b350 prime plus
Did a little more testing this morning. It's just not stable at stock. I can't take a chance that whatever the problem is is fixed with a BIOS update :/
Will have to send back to Ocuk - what a pain in behind :(
indeed I imagine if there is a general problem with these boards out returns staff will know soon enough,
Huzzah!
What's the lowdown on the Hero? I can't access Reddit at work.
Basically different results, some work perfectly, some don't POST, some are erroring out eventually. It's a mixed bag.
Could be several things, main ones being RAM support and immature BIOS.
Some people are having trouble flashing the bios if its not working out of the box. You need a usb stick and a newer bios on hand if it doesnt (go for 5803)
Guide - http://i.imgur.com/QpoP7Ye.png
Some others have corrupted updates and bricked it, which requires RMA.
Once you are up and running I cant say there's any problem apart from being pretty picky about overclocking/RAM settings, but again - immature bios.
But like me then I got error 61 on mine and wouldn't post, yet the little asus matx works like a charm, I have ordered a gaming 7 and the the little asus will be my reserve
You could setup second system with all the parts you ordered:p
Starting returns for my board. Just wish Oc wouldn't try and convince me to keep it as it may be "teething issues".
Not taking the chance I spend weeks/months waiting for possible BIOS updates to find it hasn't improved.
Wasted my long weekend on this...
What a bloody mess they have made of this release on the board front.
