CH6 installed but unfortunately no water cooler. The am3 backplate i got from the rainforest is pants. The nuts that are installed are a different pitch to the standoffs i got with the Corsair. But they fit perfect with the plates that come with the tomahawk and the CH6.
On the plus side the ram booted at 2666 first time. I'm going to play to get it to 3000.
Just installing drivers and bios updates before i begin.
Update to the latest bios 1001 mate. Keep checking the thread for updates.
http://www.overclock.net/t/1624603/rog-crosshair-vi-overclocking-thread
Hi, think I got the same AM3 back plate as you and I have installed a H100i V2, the nuts did not screw in much and I was thinking the block was not making contact but it was as the paste from the block was on the CPU and temp are very good (idles is 26C in Ryzen Master and HWMonitor).
I believe we have the same RAM yes? F4-3600C16D-16GVK
Wouldn't be better to run the 0038 (2T) bios instead of the 1001 (1T)?
Oh ok. I did not want to risk it as it felt a little loose so I stuck the stock cooler on...
Was it the yellow bracket one?
Thats reassuring I'll try it again tomorrow.Mine was the yellow one. Had the same thing with it not quite feeling right but it seems to be working.
Yes, I still keep checking temps as it just looked wrong but it is running fine? I am going to go on Bf1 a bit latter to test it out fully as temp readings could be wrong.Oh ok. I did not want to risk it as it felt a little loose so I stuck the stock cooler on...
I used flashback to 902 before powering up for the first time, did not want to brick the mobo.I'm sure my temps are wrong but im updating to bios 0902 to see if it changes.
1T is better AFAIK.
Both of the new bios shut down my pc after 10 minutes, bricking completely the system. I had no OC or any other changes from
Restoring 0902 doesn't help either. Getting error 8 and nothing else.
It will come back to you after about 4 restarts....I'm getting error f9 which I think stands for "the bios is fudged" can't get flash back to work but I just found a 3rd USB drive I will try.
Starting to think the new bios were withdrawn for a short time for this very reason. Oh well it's all fun and games![]()
