- 1 Apr 2010
I am surprised there are no custom unlocked Bios's out at all for Pascal. Big shame.
What are your overclock settings trawet?
Think mine is voltage too (green bar in GPU-Z perfcap graph) as I haven't tried the edit to unlock voltage control, won't bother until I'm watercooled either.
IMHO - the FE edition under water is a great card but you can clearly see that it is hitting the Power limit even at 1850-1950 range, very and often. To replicate this just fire up Elite Dangerous, set res to 1440p and supersample in game to x2.00. Sit back and watch afterburner blink up the limits like a mofo.
My conclusion on this is that the custom cards don't really need higher clocks to be quicker than the FE, they just need higher power limits. So, this is one of the main things to be looking for in a 1080ti AIB card if you want to water-cool it, if the power limits do not go beyond the FE then you might as well look elsewhere.
Looking back at the 1080 cards it was actually Zotac who came to the party with the most over-engineered board (the Zotac PGF with a huge 16 phases) but the card was not sold in the U.K. This leaves the Classified and the Hall of Fame as the main two with top end power. The classified will definatley bring the tools to the table but it took them an age (months!) to release them for the 1080 card.
Does it even make a worthwhile difference?
No point. Does nothing in terms of gaining extra overclocks. May help some people who are hitting power limits but that's it.I am surprised there are no custom unlocked Bios's out at all for Pascal. Big shame.
guys what am i doing wrong? I just installed my brothers 1080ti with fresh drivers, anyway benched wildlands on 1440p max settings and all we get is a 15-20pfs difference, did the bench 4 times, exactly the same system same settings, also the witcher 3 on max settings is only getting 15 fps difference, so installed the classy 1080 back in, just one card benched it again to compare with the 1080ti and its only behind by an absolute minimum.
The 1080 classy is NOT overclocked and benched at stock levels.
We was expecting at least a 50fps difference, are we expecting too much ? So is it early drivers or do we need to overclock the 1080ti?
same thing happened with my 1070 sli vs 980ti sli kingpins, I only got an absolute minimum.
Plz advise on how i can get better performance.
Any limit removal sounds good to me.![]()
and for the wait and the price premium the extra 1 to 2% performance gain just isn't worth it.
As with 1080s just buy the cheapest one with the longest warranty and hope you get lucky in the silicon lottery.
I'm talking about flashing a FE card with a custom bios not a custom board.
Well again it might give you one or two percent, fe boards don't have dual bios so if you mess up you have turned a £700 card into a doorstop etc.
Aib boards with dual bios might be worth the risk. I could understand wanting to do it if you gained 10% performance or something but with pascal the days of needing modded bios have gone.
Also last I heard is that the bios is encrypted and nobody has broken the verification encryption yet.
I've always preferred EVGA, although this time around I've went with Asus because I was a bit impatient for a new card![]()
ok i will give a warning to all those pre-ordering the msi 1080ti Seahawk. the 1080 seahawk used a founder edition reference pcb.
for this reason, unless someone has seen pcb photos, the 1080ti seahawk will not have a 150-180% power limit and will boost just like an FE card with an EK block.
this is not the droid you are looking for.
the 1080 AIO card with the best PCB was the 1080 Gigabyte Xtreme Waterforce and the 1080ti edition has not even broke cover yet. the 2nd best choice will be the EVGA 1080ti FTW Hybrid and that one probably does not yet have a CAD diagram completed never mind a production date
just to clarify, under water you will hit the power limit before the voltage limit this is why getting a board with better power delivery is more important in more respects than how much raw voltage you can put though the gpu.
if (big if) the form stays as per the 1080 the only way to bypass the 1.09v limit will be to have a custom board and if the 1080 debacle is repeated this will be limited to the asus strix OC, half of fame and the classified cards only. just these three.
you will be able to flash the bios outside of these models however you probably will not be able to set higher than 1.09v even if you can set it on the slider.
other flagships cards only have 10+2 phases.
