- 11 Oct 2007
How are none of you posting in the gfx bench threads? These are supposed to be pretty good in CPU scoring.
Prefer not having to RMA motherboards for bent pins.I don't understand why AMD don't use this chance to move to LGA socket? I removed the stock cooler the other day and the cpu came off with it! Luckily no pins were bent.
And that shouldn't have happened, since you lock the CPU in with the clip at the side, so you must have unlocked that whilst trying to unclip the cooler.
I normally give the CPU a prime95 test for a few mins just before I'm going to pull the cooler off as it softens the paste a little bit and avoids the CPU coming off with it.I don't understand why AMD don't use this chance to move to LGA socket? I removed the stock cooler the other day and the cpu came off with it! Luckily no pins were bent.
+1, I have had a CPU stuck to the cooler before.I normally give the CPU a prime95 test for a few mins just before I'm going to pull the cooler off as it softens the paste a little bit and avoids the CPU coming off with it.
@AMDMatt
What's your current settings?
I'm at:
CPU @ 4GHz (40x100.2)
RAM @ 3200MHz (3200MHz multi) 14,15,15,34,1T
1.382v vcore
1.375v DRAM
1.375v DRAM Boot
LLC Level 3
1.825v PLL
1.125v SOC
Just waiting on my AM4 bracket from corsair as I'm hitting over 80c, the contact isn't very good with the H115i and the AM3 backplate. I'm giving them until next Friday before I argue it with Corsair and OCUK to send it back for a different cooler.
The bar/clip on the right of your picture locks it in, which is what I was referencing. I havent had an intel since my E8400There isn't a hold down plate like on Intel sockets.
My h110i makes pretty good contact i think, it felt very secure when fitting. I like the AMD mounting system, simple but effective.
Odd, was under the impression it locked in. Cant say I've ever managed to pull one out of the socket. TILDone it myself in the past, as mentioned it's usually because the TIM has dried out and stuck the cooler to the CPU.
again weird, can't say I've experienced it and I've used AMD CPU's for ages but ah well. I feel like in that situation you would be equal odds on damaging pins even if they were in the motherboard.My Ryzen did also came off when tried to re-install it on Friday night, and only had fresh paste on it installed just 24 hours earlier!!!!!!
3 hour Nighthold raid 25M and Robo Recall on Oculus Rift. Both run faster than on my 5820k setup
