Yep, that's the Stormbird!The Stormbird?
I thought the Stormbird was only up in the snow? I went up to try and get a power cell from GIA but there was a missing ladder. Started making my way back down and stumbled into that thing. Its like an eagle from hell. I spent nearly an hour fighting it as it kept getting out of my view at the same time trying to survive playing hide and seek. I thought the Deathbringer was bad. Well this is a different kind of bad. The way it swoops in on you or crashes down for you.
It was frightening what was guarding the path to GIA. Ambushes everywhere. From the air, high on the rocks waiting 3 of them and Ravagers and Watchers. Ravagers and Watchers wouldn't have been so bad but not 3 Glinthawks and 3 Stalkers.
I don't like the thought of facing two Stormbirds?
They're also located around desert regions too - you can see one on the way to meridian. HERE's one for example (not porting in to check if it is the site though!)
They're easy to manage with a ropecaster apparently but I tend to stick to bow+arrow for most encounters.
I had to pause and have a ten minute break.
