It may be OK.No looks fine. Just obviously one of the pins is bent towards the other a little now as I tried to push them together...
And yep I've tried that, this so frustrating![]()
I know bud - but i'll stick with it - I can finish my work later...
IT can wait - I know how this feels.Don't let me get in the way of your work mate.
Yes - it is fiddlyNot sure how to remove it.. it is the small silver circle right?
You can use a screwdriver/credit card to hold the retaining spring back - but I'm hesitant to suggest it.
Haha I'm hesitant to try anything now. Like I said before when you said damaging the motherboard, it would just be the CMOS pins damaged right?Look at YouTube videos on how to remove a motherboard battery - and pick one that would best suit your battery and preferred method.
I'm hesitant to describe how...
Does it not have a small metal retention clip holding it in? You just need to apply a little pressure to push it back and the battery sometimes flips out.How much pressure can it take? Can't lodge anything under it no?
