What did you do to your bike today?
2 May 2004
I've used this kit to get me by while I ordered new tyre and got the time to fit it: https://www.amazon.co.uk/Gear-Greml...8&qid=1495645595&sr=8-1&keywords=tyre+gremlin. Worked nicely at plenty of speed and it might well last the life of the tyre, but it was my tyre's 2nd puncture (first was fixed with goop) so I wanted to replace anyway.
The way it fits is solid and I can't see the plugs coming out in a hurry, but you still have that pressure and way it can come out.
I'd see if the local tyre place will plug it from inside. My locals refused because of the speed rating.
24 Mar 2011
Kent
Got a set of Aprilia Performance rearsets delivered :D
And couldn't resist 'test' fitting them :D
Glad I did, thought I'd found an issue as the OEM rearset plate is much thicker than the new one, the OEM bolts protude about 15mm the other side of the frame, a few mm from the swingarm and no more than 5mm from the chain :eek:
A bit of a lightbulb moment, and I found that the handlebar clamp bolts are a) exactly the same style and thread size and b) 15mm shorter!! And the longer bolts fit perfectly into the handlebar clamp, loads of room left. it's like they were made for them!!
Need to pick up some loctite (big v-wtin vibrations!) and some more DOT4 brake fluid to give the rear brake a bleed as these rearsets re-locate them away from the engine and vertical rather than horizontal.
25 Oct 2002
Sarf Lahndahn
Rode my bike to work.
What else was I going to do to it today? Well, ride it home again. Except there's a KTM 990 SM-T sized air gap where it was. Two bikes nicked now from the area. Kentish town is such an utter hole. I hate it.
28 Feb 2006
No longer riding an Italian
Took a photo of it...
Also found I'm a brand whore :(
Thankfully only the knee guards were full price, the rest I picked up on offer or last lines :D
Edit: I know she's dirty - that's last summer's carp, and it's keeping that on, that has brought out the sun - so don't moan :p
1 Aug 2006
Scum of the earth I despise them hope it all works out for you.
OP
8 Oct 2005
Oxfordshire
Well not today, but came back last week from the 44teeth Parcmotor SummerHoliday. My god what an amazing time. I made lots of new friends and enjoyed 3 days of open pit lane fun in 26 degree heat with only 40 bikes there. Speaking to Baron, Al and Scott Reading was just awesome. Here are some shots.
Can't wait to go again next year.
