need your feedback (pc build)
OK. I guess you're not sure if that might cause any damages to components
i'm sure it won't damage components.
But i'm also sure your Pre-installed Windows, even if it were to boot up, would become corrupted overtime due to the new chipset/components in your new build.
It's always advisable to do a fresh install on a new system - even when chipsets are similar (yours are not - totally different).
Windows 10 does a better job - but even that borks after a while...
Question; will windows installation screen pop up if there is no storage device plugged in?
Should do - i'm guessing it will notify you that there is no storage device available.
What are you trying to do - test if your installation usb is OK?
Ok PC is up and running perfectly. Unfortunately I'm experiencing this driver problem that occurs sometimes when people try to install from USB. I trying to get this resolved
Great!
Not sure what you mean.
Did you disable recommended updates? Only have critical updates enabled.
And don't use the MB DIsk - download the chipset drivers from INTEL and the GFX card drivers from nVidia.
Other drivers direct from the components site - i.e. download.
Don't install any bloatware or addons that you wont be using.
I don't even have windows installed. Google USB windows 7 installation driver error
Just to clarify - you haven't booted into Windows on your old Windows install on your new machine?
If you didin't - did you delete the partitions and create a new one etc... before trying to install WIndows again on the same drive?
Will have to google later tonight - cooking.
As you're not using an SSD - try changing the sata controller from AHCI to IDE within the BIOS.
Save and exit.
Then try the install process again - hopefully it wont ask for additional drivers.
Test - let me know how you get on.
