Good, we are back to the point now. I didn't see or hear the same crap about food banks and tramps that I do now at any time in the eighties. So why did you compare now to Thatchers time? Usual Thatcher bashing by someone that thinks its an easy target eh?
BTW there are about a third of the homelss families that there were in 2003 after 6 years of economic boom under Labour according to Shelter. Square that if you can.
http://england.shelter.org.uk/campa...igures/subsection?section=homeless_households
The only person ever straying from the point was you.
What you saw up in Halifax in the 80s is irrelevant, you suggest immigration as the major factor in homelessness/housing shortage and then declared you can't deny facts, none of which you had posted.
While we are on facts, lets not post selectively from shelter.
http://england.shelter.org.uk/campaigns_/why_we_campaign/the_housing_crisis
For decades, successive governments have failed to build the homes we need. By 2008, the number of new homes being started had fallen to its lowest peacetime level since 1924 – and house building has barely recovered since then.
And on the Building of Social Housing since 1946 (graph half way down, 1980 onwards may just show a trend?):
http://england.shelter.org.uk/campa...and_figures/subsection?section=housing_supply
If only someone on the thread had suggested anything like this to you.
lets also consider figures of the increase in rough sleeping since 2010, homeless.org.uk suggest it's 134%
http://www.homeless.org.uk/facts/homelessness-in-numbers/rough-sleeping/rough-sleeping-our-analysis
http://www.homeless.org.uk/facts/homelessness-in-numbers/rough-sleeping/rough-sleeping-explore-data
Doubtless they are mostly immigrants, in any case, destruction of local government (a Thatcher policy and Tory Ideal) is more reasonable to suggest as a major factor in increasing deprivation and difficulty for keyworkers and first time buyers to get on the ladder. Good luck with your buy to let business. If you were any good at it, I'd expect you already looked at some factual data around housing. As I suggested based on your earlier posts, "some men you just can't reach".
