I would advice against using LLC on the CH6 board. I cannot speak to the others but the stilt over at oc.net has posted that LLC gives an overshoot of voltage after coming off a high load.
This cannot be seen on CPUz or the likes or even a multi meter but rather an oscilloscope. What you think could be 1.45v could very well be spiking into the 1.5v without you even seeing it.
The advice is to run a higher idle voltage to compensate for droop and ignore LLC. Or if for whatever reason you need to use it then don't go above level 2.
