- 21 Apr 2013
Plec the slacker
I would need the spec - but it sounds a premium piece of kit?It was custom built one so don't think it has a specific model number.
Will be worth the wait.I am, but it's going to have to wait a good while!
Well the base clock makes sense but the boost number is nuts (would be great).I've got a question regarding afterburner, it's showing 1683 base and a 5508 boost....
It's the Gaming X plus Plec.
Just played Max Payne 3, for a game that came out 5 years a go on Ultra I'm not reaching the 144FPS.. is that concerning?
Sounds about right with everything maxed/ULTRA.Getting between 90-130fps so shouldn't moan but just seeing as it came out in 2012 expected the full 144. Yeah that would be great.
No need while you're running a 1080P monitor.I don't know if I've put it in Gaming Mode, I haven't touched anything, do you suggest I do?
What is AGESA?
AMD Generic Encapsulated Software Architecture (AGESA), is a bootstrap protocol by which system devices on AMD64-architecture mainboards are initialized. The AGESA software in the BIOS of such mainboards is responsible for the initialization of the processor cores, memory, and the HyperTransport controller.
Sorry, Beady, i wouldn't know where to begin pricing that - especially as it's essentially a 13.3" gaming laptop with an IPS screen (nice bit of kit).![]()
Laptop specs.
Surprised - but it can happen unfortunately.Been trying to get it to 3200 but just won't have it still. Any ideas Plec?
I've done other builds similar to yours - almost the exact same spec - one hit 3200MHz with the new F7 Official and the other hit it with the F6. But no two sticks/sets are the same so it's always a bit of lottery especially with early formats.
We could play with the timings, tweak voltages slightly - but i would be tempted to wait as your system is rock solid and you've been relatively lucky hitting 3000MHz straight out the box (for 2 months) - some people are only now experiencing that.
The speed gains are surprisingly good for only 200MHz - so we will push for it if the next update doesn't help. But stability is always king and i've read too many threads where members are having a torrid time trying to get their system stable for the sake of 200MHz. Which is fine if you know what you're doing but perhaps not so wise if you're not familiar with the process and have a perfectly working system that's stable at an already very respectable speed.
I would hope so - pee'd that it hasn't got there now for you. But, as mentioned, you hit 3000MHz with ease which was a real bonus so early on.Damn that's a shame. Here's hoping that the next update will get to the magic number then!
Yes, Windows will pick it up on the reboot.Setting up a second monitor today, do I just plug it in to the graphics card and it will sort itself out or do I need to change some settings for it to work?
